2018-07-12 04:00 AM
2018-09-20 12:48 AM
2018-09-20 03:09 AM
Geoff wrote:
1) In order to change the segment height of one segment relative to the other you need to first "Create Independent Segments and Nodes (context or Design menu). I missed that fact and was stuck until I figured it out.
Geoff wrote:
2) It would be great if the tool allowed graphic editing of the segment height in elevation & 3D. My sloped segment was already correct by virtue of being associated to the stair. All I needed to do was raise the flat segment and a simple drag in 3D would be fast and easy.
2018-09-20 03:14 AM
Geoff wrote:
4) When independent segments are created the Ending Node Offset becomes independent too, which is great since the two ends can then have different settings. But like other custom settings in this tool, you have to select the now-custom node in edit mode first. The overall setting found when selecting the entire railing no longer applies.
Geoff wrote:Basically, yes.
So the takeaway is that once the segments are independent you need to go into edit mode to do most everything.
