‎2005-01-31
12:14 PM
‎2023-05-24
12:49 PM
Rubia Torres
‎2005-01-31 12:38 PM
‎2005-01-31 02:47 PM
‎2005-01-31 04:59 PM
‎2005-02-01 03:39 AM
Julia wrote:what gemma said. also, does using a v9 library actually work with v8 anyway? even if you do change all your "windowV8" library parts that are placed in the model to simply "window" (v9) parts i don't believe v8 will recognise them if you open it with that anyway . . . i could be wrong?
When I open a V8 plan in V8 . . .
‎2005-02-01 08:39 AM
‎2005-02-01 11:26 AM
‎2005-02-01 01:05 PM
Julia wrote:julia - if this is the case then quite honestly i would leave it alone and chalk it up to experience . . .
The reason I need it to change smoothly is there are about 200 licenses using this library along with a database taking quatities.
‎2005-02-01 02:17 PM
Julia wrote:
Have a look at the window schedule pdf at www.parametricprojections.com.au it is on the library/window page and you know why I made my own window.
~/archiben wrote:
you will see graphisoft themselves have only just got out of the habit of naming each library part with a version suffix so that they are now forward compatible...
i think as long as your users can only access your set libraries they will use it no matter what version of archiCAD you're using. or you could begin running two company libraries in parallel - one for "*v8" parts and one where you will gradually phase in forward compatible, updated parts for 9 onwards . . . although this brings obvious policing problems.
‎2005-02-02 01:07 AM
julia - if this is the case then quite honestly i would leave it alone and chalk it up to experience . . .Yeh, just a bit annoying it works for objects but not windows and doors.
ps - where are you based in australia?Perth.
