Repeat 2d Object
I have attached a screenshot of a 2d symbol which, when I draw it beyond its length, I would like it to repeat (like the 2d insulation object in archicad.)
As you can probably guess, the 2d script so far is a cleaned up automated script straight out of archicad. Would anyone be able to give me some guidance on how to go about scripting the object to loop?
My understanding is that I would FOR... NEXT loop and get the object to repeat if I set it out longer than its length but, after studying other objects and looking around online, I still don't really know where to start!
Ive posted the basic code below:
mul2 A/0.107482, B/0.019122
add2 -59.16268087103, 96.73000278751
pen 6
set fill "Solid Fil1"
poly2_b{5} 5, 3, 0, 3, 120, 0,
0, 0, 1, 0, 0, 1, 0,
59.16268087103, -96.71088119978, 1,
59.2155617965, -96.71088119978, 1,
59.2155617965, -96.73000278751, 1,
59.16268087103, -96.73000278751, 1,
poly2_b{5} 5, 3, 0, 3, 81, 0,
59.27016330366, -96.71088119978, 1,
59.27016330366, -96.73000278751, 1,
Thanks,
Richard
1 Reply 1
Here is one piece of code that should work. You can put it
all in the master script - alternatively could be splitted between
value and 2D scripts.
Hope this makes sense, example object attached.
!--needed new parameters are present in the example object
!--master or value script
values "grid" 1, range[0.1, ]
values "a" grid, range[grid, ] step grid, grid
values "b" 0.1
!--master or 2D script
eps= 0.0001
pen L_
parts= int((a+eps)/grid)
for xx=1 to parts
	if fra(xx/2) then	!--odd round
		fillpen= pen_1
		fill fill_1
	else				!--even round
		fillpen= pen_2
		fill fill_2
	endif
	poly2_a 4, 1+2+4, fillpen,
		0,	0,	1,
		grid,	0,	1,
		grid,	b,	1,
		0,		b,	1
	add2 grid, 0
next xx
del xx
Regards, Juha
