Requesting Door Leaf Dimension in Marker Object
jakubc7
I am trying to 'output' door leaf dimension to use in a 'Dimension Marker'.
I have no problems with getting the width and height :
l1a = STR("%.0mm",AC_WIDO_B_SIZE)
l1b = STR("%.0mm",AC_WIDO_A_SIZE)
However I cannot figure out how to output the 'ac_leaf_width' as it is not part of the Marker Parameters but the Door Object Parameters.
I tried using this request which I noticed on another marker (AUS D&W Marker) and GDL Reference seems to suggest the command to request object's parameters for listing:
leaf_w = request ("ASSOCLP_PARVALUE", "ac_leaf_width",
index_lw, type_lw, flags_lw, dim1_lw, dim2_lw, leafwidth)
But it does not let me 'output' 'leafwidth' parameter.
I'm not sure what I'm doing wrong.
Can anyone enlighten me please?
Thanks.
Jakub
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
4 REPLIES 4
I can't test it, but think declaring the variable first might help;
leafwidth= ""
leaf_w = request ("ASSOCLP_PARVALUE", "ac_leaf_width", index_lw, type_lw, flags_lw, dim1_lw, dim2_lw, leafwidth)
Alternatively you could create a string type parameter 'leafwidth'
Hope this helps.
jakubc7
Thanks for the reply Juha.
Declaring the parameter first seems to get rid of the "uninitialised" error, however it still doesn't assign the ac_leaf_width value to that parameter.
Thinking about it, how does ArchiCAD/GDL know which object to get the parameter from. I suppose ac_leaf_width could be used in more than one object. Do I have to specify which object to get the parameter from?
I'm attaching my object as well as the gs_DW_Marker.gsm where they seem to do it successfully ... but it is a much more complex process that I cannot follow
jakubc7
markers
jakubc7
Ohh wow ... I feel a little silly.
The whole time I've been testing the "Marker" on a window 😕
The request seems to work fine on a door object.
leafwidth=0
I used the 1st line so that I do not get an error when working with a window.
Thanks for trying to help
