Your roofs and ceiling all need to be just one composite (not possible if the skins are not parallel.
It is like windows in wall - you don't model each wall skin separately.
I am about 90% confident it would be possible to tweak the GDL of the skylight to include a shaft that would cut holes only when an SEO is performed between the skylight and the other roof skins - would still need to be done manually (but I have never really looked at a skylight script so can't be totally confident it would work).
It would be easy to just model the shaft and SEO that - depending on how many you have to do.
