Right Triangle Window in ArchiCAD 11: Can ?
aloha
I am unable to create a 'right' triangle window in AC 11.
Using the W Triangle Fix 11
When I bring the 'Top edge from zero' to 1/2 of the window width,
I get an invalid 3D symbol msg.
mahalo for your kokua !
thanks for your help !
1 REPLY 1
It can be done in 12 with the 'W Triangle fix 12' object.
http://archicad-talk.graphisoft.com/viewtopic.php?t=46933
I don't have 11 installed but if it can't be done there then I may be a bug in the library part.
Setting the offset to half of the width should work - that is all I did in 12.
