Rise and Run in stair label
RandyC
In Canada we use rise and run for stairs , but the archicad - Stair Dimension label 22 uses "going"
I have received compaints about the use of this word -- is it possible to change "going" to "run"
by just doing a search and replace in the script of the stair label ?
Thanks,. Randy
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
7 REPLIES 7
Randy, doesn't the label give you the option of giving your own term to the label? seems to me I've been able to not have to use the word going.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
RandyC
HI Aaron , I cannot find anywhere that I can change the wording and looking at the script it not a parameter
I wondeer if they use the word "going" in the united states ? nobody here seems to of heard of it around here.
Randy
RandyC
Same library part --- Stair Dimension Label 22 --
another problem - it is taking up too much real estate on the page How can I shrink the area between Id and dimension ?
there are two places: for plan labeling, and for the stair label
Rhino 8 Mac
MacOS 14.2.1
label tool didn't upload.
Rhino 8 Mac
MacOS 14.2.1
RandyC
Thanks for the help Aaron -- It takes a bit of time to go thru each library part to find the correct settings - I should of spent longer but time is often at a premium .
You would think Graphisoft would change some of those wordings on the North America Library to terms that we use.
I found the answer to my last question -- I needed to check the "uniform formatting" box - I am including a screenshot for anyone else that may have trouble finding it. -- Thanks Again.
Palawat
It's in Master Script.
dim	stDimContent[5]
	stDimContent[1]	= `None`
	stDimContent[2]	= `Stair Width`
	stDimContent[3]	= `Riser Height`
	stDimContent[4]	= `Going Depth`
	stDimContent[5]	= `Number of Risers`
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
