Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
SOLVED!
Archicad 25 on Monterey crashes when exporting DWG or DXF Build 4013
Hi all,
When I am trying to export to dwg or dxf from Archicad 25 on Monterey it crashes just after you choose skip the .shx files.  I have not really had to export to Autocad for a very long time but I did not expect this response.  The file contains zones, a stair case object.  It also contains couple of other objects one for an underground tank and another for carparking access assessment.  It is a feasibility drawing so not really that complicated.  Can anyone suggest what the issue might be?
Does anyone have a dwg template file that I could use as a source to help with export?  I thought this might be a work around?
I have yet to upgrade to the latest build because of the bug with the custom drawing label.  I am unsure whether to upgrade to test the file or not.  Any help welcomed.
Kind regards,
Sebastian Monroe
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
1 ACCEPTED SOLUTION
Solution
Found error. Some of my attributes had numbers outside of the recommended range. Problem solved.
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
6 REPLIES 6
Martin Jules
Mentor
@Sebastian Monroe You should be correct by upgrading your Archicad 25 to the latest build 5005.
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
Also, is this happening on macOS 12.3?
There have been various reports in the Community about crashes on this latest macOS version:
https://community.graphisoft.com/t5/Setup-License-forum/Archicad-crashes-on-macOS-12-3-when-closing-...
Solution
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
There is a recommended range for attribute numbers?
Is there any information you can share please?
Mats_Knutsson
Mentor
We have the same problem with on a 25-project (windows). We haven't started using 25 yet so it's a pilot project. Using our 23 dwg translator...Will have a look at the attributes but I'm also interested in the "recommended range"...never heard of it.
AC 25 SWE Full
@Mats_Knutsson try if you can find the answer in the following book: https://www.amazon.com/Archicad-AutoCAD-Users-v15-US-MacKenzie-ebook/dp/B007AMMOPA/ref=mp_s_a_1_1?cr...
Martin Luther Jules
AC 10-28 (Full)
