Archicad 25 on Monterey crashes when exporting DWG or DXF Build 4013
Hi all,
When I am trying to export to dwg or dxf from Archicad 25 on Monterey it crashes just after you choose skip the .shx files.  I have not really had to export to Autocad for a very long time but I did not expect this response.  The file contains zones, a stair case object.  It also contains couple of other objects one for an underground tank and another for carparking access assessment.  It is a feasibility drawing so not really that complicated.  Can anyone suggest what the issue might be?
Does anyone have a dwg template file that I could use as a source to help with export?  I thought this might be a work around?
I have yet to upgrade to the latest build because of the bug with the custom drawing label.  I am unsure whether to upgrade to test the file or not.  Any help welcomed.
Kind regards,
Sebastian Monroe
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
Found error. Some of my attributes had numbers outside of the recommended range. Problem solved.
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
6 REPLIES 6
Martin Jules
Mentor
@Sebastian Monroe You should be correct by upgrading your Archicad 25 to the latest build 5005.
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
Also, is this happening on macOS 12.3?
There have been various reports in the Community about crashes on this latest macOS version:
https://community.graphisoft.com/t5/Setup-License-forum/Archicad-crashes-on-macOS-12-3-when-closing-...
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
There is a recommended range for attribute numbers?
Is there any information you can share please?
Mats_Knutsson
Mentor
We have the same problem with on a 25-project (windows). We haven't started using 25 yet so it's a pilot project. Using our 23 dwg translator...Will have a look at the attributes but I'm also interested in the "recommended range"...never heard of it.
AC 25 SWE Full
@Mats_Knutsson try if you can find the answer in the following book: https://www.amazon.com/Archicad-AutoCAD-Users-v15-US-MacKenzie-ebook/dp/B007AMMOPA/ref=mp_s_a_1_1?cr...
Martin Luther Jules
AC 10-28 (Full)
