‎2022-03-27 02:13 PM - last edited on ‎2022-03-29 02:35 AM by Karl Ottenstein
Hi all,
When I am trying to export to dwg or dxf from Archicad 25 on Monterey it crashes just after you choose skip the .shx files. I have not really had to export to Autocad for a very long time but I did not expect this response. The file contains zones, a stair case object. It also contains couple of other objects one for an underground tank and another for carparking access assessment. It is a feasibility drawing so not really that complicated. Can anyone suggest what the issue might be?
Does anyone have a dwg template file that I could use as a source to help with export? I thought this might be a work around?
I have yet to upgrade to the latest build because of the bug with the custom drawing label. I am unsure whether to upgrade to test the file or not. Any help welcomed.
Kind regards,
Sebastian Monroe
Solved! Go to Solution.
‎2022-03-29 02:16 AM
Found error. Some of my attributes had numbers outside of the recommended range. Problem solved.
‎2022-03-28 02:53 AM
@Sebastian Monroe You should be correct by upgrading your Archicad 25 to the latest build 5005.
‎2022-03-28 04:58 AM - edited ‎2022-03-28 04:59 AM
Also, is this happening on macOS 12.3?
There have been various reports in the Community about crashes on this latest macOS version:
‎2022-03-29 03:57 AM
There is a recommended range for attribute numbers?
Is there any information you can share please?
‎2022-04-04 01:38 PM - edited ‎2022-04-04 01:42 PM
We have the same problem with on a 25-project (windows). We haven't started using 25 yet so it's a pilot project. Using our 23 dwg translator...Will have a look at the attributes but I'm also interested in the "recommended range"...never heard of it.
‎2022-04-04 02:23 PM
@Mats_Knutsson try if you can find the answer in the following book: https://www.amazon.com/Archicad-AutoCAD-Users-v15-US-MacKenzie-ebook/dp/B007AMMOPA/ref=mp_s_a_1_1?cr...
