Rotate Object In Space
Scott Bulmer
An article was just posted on ArchiCADWiki titled 'How to rotate an object in space' shown here: http://archicadwiki.com/RotateObjectInSpace
This creates an object with a fixed rotation of 90 degrees to the original model.
Is there a simple way to rotate a custom created object relative to the Z axis similarly to how SketchUp can rotate an object? It would be great if a Vertical Rotation field could be added to the Parameters for custom made objects. Thanks for any thoughts. Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Hello Scott,
Please see this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=5402&highlight=rotate#5402
Specifically, Djordje's post about how to create rotation parameters
and how to add rotation commands to the 3D script.
Peter Devlin
Scott Bulmer
Peter, that is so money! Djordje's explanation should be posted as a follow up to that initially posted on ArchiCADWiki.
Thanks, Scott
