Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
JGoode
Rotating Dynamic Hotspot Help?
I have tried using the script given in the gdl guide but I can't seem to get it to work. Does anyone know how to make it work correctly?
! Center
hotspot2 0, 0, unID, ang, 6     : unID = unID + 1
! Base
hotspot2 r, 0, unID, ang, 4     : unID = unID + 1
! Moving
hotspot2 r * COS(ang), r * SIN(ang), unID, ang, 5     : unID = unID + 1
I have created parameters for ang and R.
I really just need some explanation of the code. For some reason the angle increases when going anti-clockwise instead of clockwise. In 2D. The base does isn't position above at what should be 0 degrees.
ArchiCAD 27
Windows 10
4 Replies 4
Erwin Edel
If I look at page 197 of the GDL Reference Guide in ArchiCAD 20, the diagram is quite clearly going counter clockwise, perhaps this is intended?
Edit: this is also how the angles work in ArchiCAD when drafting.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
JGoode
Seems very strange. I was having some other issues when changing the centre point of the rotation so I have had to keep it at 0, 0 which is inconvenient. Thanks for the help.
ArchiCAD 27
Windows 10
All of the hotspots need to have the same base co-ordinates.
An easy way to do this is leave the base at 0,0 but put an ADD before the hotspots
i.e.
ADD x, y
! Center
! Base
! Moving
DEL 1
or
 ! Center
hotspot2 x+0, y+0, unID, ang, 6     : unID = unID + 1
! Base
hotspot2 x+r, y+0, unID, ang, 4     : unID = unID + 1
! Moving
hotspot2 x+r * COS(ang), y+r * SIN(ang), unID, ang, 5     : unID = unID + 1
Adding a flag value of 512 to the centre hotspot (type 6) will make it rotate in the opposite direction.
JGoode
i.e.
ADD x, y
! Center
! Base
! Moving
DEL 1
or
 ! Center
! Base
! Moving
Thanks very much. This is very useful.
ArchiCAD 27
Windows 10
