Rotation in 2d do not have any effect in the "Preview and p.
I have made an object. The 2d script works fine when the object is open.
The display in the Parameters shows a rotated 2d object as it should.
I put an instance of this object in the floorplan.
I watch the display in the "Preview and positioning" and put 45 degrees in the box, but no effect on the 2d symbol in the display.
I have deleted and reloaded the object in the Library Manager.
Also I used to be able to open an object when I selected an instance in floorplan, and pressed ctrl + O. But now I only open the filedialog with this command.
Maybe some connection between the problems?
10 REPLIES 10
Now I've deleted the test and the rotation command. And now it works correctly. So thanks for all your help 🙂
