Rotation of text in windows/doors marker inside a rotated drawing in layout
when I put a drawing in a layout (for example floor 1) and I rotate it for a better print, the marker's text of windows and doors does not rotate relative to the orientation of the layout but rotates rigidly together with the rotation of the drawing.
In this way I can have texts upside down.
In the model this does not happen and the marker text is always oriented correctly even if I rotate the view.
It only happens in layouts.
Is there a parameter for managing this aspect in drawings / layouts ??
Thanks in advance.
1 Reply 1
Guru
The Always Readable parameter is only valid for Views. You will need to save a new View.
Ling.
