SECT_FILL does not work with cWall in AC12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-05-12 10:37 AM
Has anybody an idea how to easily add a section fill without rewriting a complex shape with another command?
GDL object creation: b-prisma.de
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 01:23 PM
SECT_FILLS settings show at the first time during half a second, and are replaced by current Section settings, with Cut Fill Background Pen missing.
I don't see a solution.
Quick testing with cWall part called as a macro, and same bad result. This is for GS.
Did you try xWALL_, which syntax looks close to cWALL_?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 01:46 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 02:32 PM
But punish me, I wrote the wrong commad name.
It was not cWALL_ that I was working on; it was cROOF_.
And there seems to be no xROOF_.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 03:07 PM
Joachim wrote:Bingo! Two bugs at once. cROOF_ and cWALL_.
Hi Olivier, thankm you for your rapid answer.
As you said, not any xROOF_ command. This is anoyous.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 04:07 PM
Are you sure to put a SECT_FILL sentance before each cROOF_ ? I can't reproduce what you decsribe.
With cWALL_, for sure there is a bug. Neither SECT_FILL or SECT_ATTRS work in AC12. It worked before.
With cROOF_, I am not sure. Could someone else verify?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 04:24 PM
Thanks for letting us know about them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 05:02 PM
But with the example of the GDL manual it also does not work.
I added the command for SECT_FILL. gr_fi is defined in the parameter list.
I enabled "Objects attributes" at Floor Plan and section.
If I then use there (Objects attributes) a fill that is not empty, the fill is seen,
but it is not the one defined in the SECT_FILL: This behaviour (I think) should not be.
L=0.25
R=(0.6^2+L^2)/(2*L)
A=ASN(0.6/R)
SECT_FILL gr_fi,SYMB_FBGD_PEN,SYMB_FILL_PEN,SYMB_SECT_PEN
CROOF_ M_,M_,M_,
16, 2, 0, 0,
0, 0, 45, -0.2*SQR(2),
0, 0, 0, 15,
3.5, 0, 0, 15,
3.5, 3, -45, 15,
0, 3, 0, 15,
0, 0, 0, -1,
0.65, 1, -45, 15,
1.85, 1, 0, 15,
1.85, 2.4-L, 0, 13,
1.25, 2.4-R, 0, 900,
0, 2*A, 0, 4015,
0.65, 1, 0, -1,
2.5, 2, 45, 15,
3, 2, 0, 15,
3, 2.5, -45, 15,
2.5, 2.5, 0, 15,
2.5, 2, 0, -1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 05:18 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-12 09:48 PM
Since my test example worked, I found a possible culprit.
Closing the contour leads to an error. Thus, just puting a hole inside cROOF_ get the section wrong. AC12 only.
for k = 1 to 2 body -1 sect_fill 69, 0, 10, 7 put 0.00, -0.50, -50.00, 15, 0.00, 0.50, 30.00, 15, 2.00, 0.50, -40.00, 15, 2.00, -0.50, 30.00, 15 ! put 0.00, -0.50, -50.00, -1 !!! closing = get error croof_ mat, mat, mat, nsp/4, 0.00, -0.50, 0.00, 0.50, 0.00, 10.00, 0.30, get(nsp) addz 1.00 next k del 2
