2011-01-01 12:21 PM
2011-01-01 09:57 PM
2011-01-02 05:53 AM
2011-01-02 05:22 PM
sadones1 wrote:Only possible using the ArchiCAD API.
Can a GDL object know information about the (nearest) slab on top of which it is positioned, in the same story ?
(distance to the slab, thickness of the slab)
2011-01-02 07:34 PM
vfrontiers wrote:Unless something has changed the gravity function will only drop things onto slabs, roofs and meshes but does not maintain the relationship after the initial placement.
2. Use the GRAVITY to lock to top of slab
2011-01-03 12:25 AM
Matthew wrote:Right... I was only suggesting that at PLACEMENT it would know the top of slab and could "hover" above it...vfrontiers wrote:Unless something has changed the gravity function will only drop things onto slabs, roofs and meshes but does not maintain the relationship after the initial placement.
2011-01-03 03:03 AM
vfrontiers wrote:I figured you knew. I just had to comment, partly because I WISH we could lock in the relationship.Matthew wrote:Right... I was only suggesting that at PLACEMENT it would know the top of slab and could "hover" above it...vfrontiers wrote:Unless something has changed the gravity function will only drop things onto slabs, roofs and meshes but does not maintain the relationship after the initial placement.
2011-01-03 06:15 AM
2011-01-03 06:21 AM
2011-01-03 09:35 AM
