2007-03-15
10:34 PM
2023-05-24
12:05 PM
Rubia Torres
2007-03-15 10:41 PM
kegroup wrote:Floor Plan and Section>Enable Object's Pens check box?
What am I missing, here?
2007-03-16 06:20 AM
2007-03-16 07:43 PM
~/archiben wrote:kegroup wrote:Floor Plan and Section>Enable Object's Pens check box?
UNchecking the use objects pens did the trick. Still don't know why I can't get to whatever pen it's using, however.
~/archiben
2022-12-22 02:24 AM
I am having the same problem, and I checked and unchecked the Enable Objects pens to no avail.
2022-12-27 11:32 AM
2raarchitecture,
You answered a 15-year old thread. The Stair tool did not exist at that time (what existed at that time was another tool called StairMaker).
Can you give more detail (possibly with screenshots) about the issue you are facing?
2022-12-28 01:51 AM
Thank you kindly for your reply. It's not helpful to tell people how old a post is. The solution was to change the model view options for both railings and stairs to full instead of simplified. Please, see attached.
2022-12-28 12:47 PM
Thanks for the solution, hopefully, others will find it useful.
By the way, there is no attachment in your last post.
