2006-10-02 04:41 PM
2006-10-05 12:33 PM
F. wrote:There is a version of the converter for every version of ArchiCAD from 8 to 10. Each produces objects suited to its corresponding ArchiCAD version, but the XML source may have come from any other version. For example, I could convert an AC10 object to XML using the AC10 converter, and then convert the XML to an AC8 object using the AC8 converter.
But you will need the recent versions of the XML converter for downgrading, isn't it? The actual downloadable one will create objects for AC10 (Version 21 or 22 I guess).
