Tendenz
Saving object in AutoCAD as to not lose materials
Hi everybody!
I have gotten a large number of DWG 3D objects from our suppliers. When I open these in ArchiCAD I lose the ability to change materials.
I have downloaded the trial version of AutoCAD 2014, but I just realized they quit the option for exporting to 3DS.
How can I export / save the objects the best was, so as to be able to change materials in ArchiCAD later?
Or should I try a different program, rather than AutoCAD?
GRATEFUL for all help!
iMac OS X 11.6
2,3 GHz Intel Core i9, 16 GB 2667 MHz DDR4
ArchiCAD 25
2 Replies 2
You can convert a GDL Object to a Morph, modify the surface materials of its faces, then save it back as a GDL Object.
If you need to change material once go with Laszlo solution.
If you want to make material a parameter then things became a little more complicated.
Roughly:
start from gdl imported material, create as many material parameters as you need, scan the code overwriting material names with your parameters names and save as gdl object.
