Scaled vs Fixed
I have created a wall type marker, grouped geometry, nothing fancy. I can control the text size from scale to scale but I don't know how to control the grouped geometry. If I place the grouped geometry in the project map it scales with the plan. When I place the geometery in teh view map, it still happens. Is there a fixed or scalable option for 2D objects anywhere? This is basically what I am needing. How do you control a detail marker or section/elevation?
5 REPLIES 5
TomWaltz
Did you save it as an object? Or did you just group the lines and text together?
Tom Waltz
First just grouped then saved as an object.
TomWaltz
OK. The grouping becomes irrelevant once you save them as objects.
The scale sensitivity has to be scripted in. The command you're looking for is MUL2.
Tom Waltz
__archiben
... combined with the GLOB_SCALE global variable.
~/archiben
b e n f r o s t
I have same problem about scalable text in objects. Below the 2D Script Code. But text don´t keep size (1,5mm) when I change the scale. This object was made from an DWG block.
Anyone can help?
!!! ??? order of transformations ???
mul2 xs, ys
rot2 angle
DEFINE STYLE STYLE_1 "Arial Ocidental", (1000 / GLOB_SCALE) * BB * ys * 0.075, 5, 0
STYLE STYLE_1
PEN 66
TEXT2 -0.293859, -0.00221908, TAGNAME_20
TEXT2 -0.0236509, -0.000972388, TAGNAME_20
TEXT2 0.258843, -0.0061859, TAGNAME_20
FRAGMENT2 ALL, 0
