Script creates extra hotspot
Hi all. I am trying gain a better understanding of editable hotspots. It was going well until this happened. (See attachment) I've studied it but can't figure out why it's creating the extra hotspot when HOTSPOT A is moved. Is there something special that needs to be scripted in order to have more than 1 editable hotspot in an object? I still have a couple more that I need to add.
Thanks, Doug
unID = 10000
hotspot2 BEARING_1_X, 0, unID, BEARING_1_Y, 1+128 : unID=unID+1
hotspot2 BEARING_1_X, -1, unID, BEARING_1_Y, 3 : unID=unID+1
hotspot2 BEARING_1_X, TRIB_1_Y, unID, BEARING_1_Y, 2 : unID=unID+1
hotspot2 0, BEARING_1_Y, unID, BEARING_1_X, 1+128 : unID=unID+1
hotspot2 -1, BEARING_1_Y, unID, BEARING_1_X, 3 : unID=unID+1
hotspot2 BEARING_1_X, BEARING_1_Y, unID, BEARING_1_X, 2 : unID=unID+1
unID = 20000
hotspot2 TRIB_1_X, 0, unID, TRIB_1_Y, 1+128 : unID=unID+1
hotspot2 TRIB_1_X, -1, unID, TRIB_1_Y, 3 : unID=unID+1
hotspot2 TRIB_1_X, TRIB_1_Y, unID, TRIB_1_Y, 2 : unID=unID+1
hotspot2 0, TRIB_1_Y, unID, TRIB_1_X, 1+128 : unID=unID+1
hotspot2 -1, TRIB_1_Y, unID, TRIB_1_X, 3 : unID=unID+1
hotspot2 TRIB_1_X, TRIB_1_Y, unID, TRIB_1_X, 2 : unID=unID+1
SET LINE_TYPE 49
LINE2 0, 0, TRIB_1_X, TRIB_1_Y
1 Reply 1
It's amazing how you can walk away from a problem for a couple of minutes, come back to it and instantly have the cause staring you in the face.
This was a copy and paste. Apparently I didn't feel the need to make all the necessary changes.
