Script windows do not hold thier position
Hello,
Has anyone noticed that in the GDL editing environment in AC 10
the size, position, and font selection of the script windows are not remembered from one session to the next.
These prefs used to be stored in the "dialposition prefs" but
apparently now they are not remembered.
If anyone can confirm this I will report it to GS.
Thank you,
Peter Devlin
11 Replies 11
Jeff,
I believe, in versions prior to AC 8.1 the frame depth was a dimension
type parameter that if set to zero would make the frame
depth equal to the wall thickness.
You are right.
In AC 8.1 and AC 9 there is a boolean parameter called
"FRAME DEPTH=WALL THICKNESS" ON/OFF.
Peter Devlin
Jefferson
........and I miss it!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
