TomWaltz
Title size Parameters?
Has anyone figured out how to get the widht/height of a placed Drawing for use in a title object?
How about any "request" information or built-in parameters? There does not seem to be anything in the GDL Dev Kit or the Reference Manual about it.
Tom Waltz
8 Replies 8
Frank Beister
Create a new object and change to subtype "title block"/"drawing title" (? "Zeichnungstitel" in GER). You will see some optinal parameters (blue) wich will contain the informations you are looking for. (I guess 😉 )
TomWaltz
I was hoping to find a little more information the the rectangle arrays. I'll have to spend some quality time with them later this week when I have a few less fires burning.
Tom Waltz
Frank Beister
Maybe this will help you:
IF  not(AC_TextFont="") THEN
	Zeichensatz = AC_TextFont
	sh = AC_TextSize
	! HIDEPARAMETER "Zeichensatz","sh"
	ENDIF
!+++ DEFINITIONS
start = 500
GOSUB 100 !=ende
DEFINE STYLE "Links" zeichensatz, sh,3,1
DEFINE STYLE "Rechts" zeichensatz, sh,1,0
s=-sh/1000*GLOB_SCALE*1.5
t=-s/2
!+++ PRINT
FOR unterprogramm=start TO ende STEP 5
	GOSUB unterprogramm
	NEXT unterprogramm
END
!+++ SUBROUTINES
500:
STYLE "Links"  : TEXT2 0,f*s,"AC_ManualPosition: "
STYLE "Rechts" : TEXT2 0,f*s,AC_ManualPosition
f=f+1
RETURN
505:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingGUID: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingGUID
f=f+1
RETURN
510:
STYLE "Links"  : TEXT2 0,f*s,"AC_TitleFitMode: "
STYLE "Rechts" : TEXT2 0,f*s,AC_TitleFitMode
f=f+1
RETURN
515:
STYLE "Links"  : TEXT2 0,f*s,"AC_TextFont: "
STYLE "Rechts" : TEXT2 0,f*s,AC_TextFont
f=f+1
RETURN
520:
STYLE "Links"  : TEXT2 0,f*s,"AC_TextSize: "
STYLE "Rechts" : TEXT2 0,f*s,AC_TextSize
f=f+1
RETURN
525:
STYLE "Links"  : TEXT2 0,f*s,"AC_TextPen: "
STYLE "Rechts" : TEXT2 0,f*s,AC_TextPen
f=f+1
RETURN
530:
STYLE "Links"  : TEXT2 0,f*s,"AC_TextStyle: "
STYLE "Rechts" : TEXT2 0,f*s,AC_TextStyle
f=f+1
RETURN
535:
STYLE "Links"  : TEXT2 0,f*s,"AC_UseUniformTextFormat: "
STYLE "Rechts" : TEXT2 0,f*s,AC_UseUniformTextFormat
f=f+1
RETURN
540:
STYLE "Links"  : TEXT2 0,f*s,"AC_PreviewType: "
STYLE "Rechts" : TEXT2 0,f*s,AC_PreviewType
f=f+1
RETURN
545:
STYLE "Links"  : TEXT2 0,f*s,"AC_ConvertedTitle: "
STYLE "Rechts" : TEXT2 0,f*s,AC_ConvertedTitle
f=f+1
RETURN
550:
STYLE "Links"  : TEXT2 0,f*s,"AC_LayoutRect[1]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[1]
f=f+1
RETURN
555:
STYLE "Links"  : TEXT2 0,f*s,"AC_LayoutRect[2]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[2]
f=f+1
RETURN
560:
STYLE "Links"  : TEXT2 0,f*s,"AC_LayoutRect[3]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[3]
f=f+1
RETURN
565:
STYLE "Links"  : TEXT2 0,f*s,"AC_LayoutRect[4]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[4]
f=f+1
RETURN
570:
STYLE "Links"  : TEXT2 0,f*s,"AC_LayoutRect[5]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[5]
f=f+1
RETURN
575:
STYLE "Links"  : TEXT2 0,f*s,"AC_GridRect[1]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[1]
f=f+1
RETURN
580:
STYLE "Links"  : TEXT2 0,f*s,"AC_GridRect[2]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[2]
f=f+1
RETURN
585:
STYLE "Links"  : TEXT2 0,f*s,"AC_GridRect[3]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[3]
f=f+1
RETURN
590:
STYLE "Links"  : TEXT2 0,f*s,"AC_GridRect[4]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[4]
f=f+1
RETURN
595:
STYLE "Links"  : TEXT2 0,f*s,"AC_GridRect[5]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[5]
f=f+1
RETURN
600:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingRect[1]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[1]
f=f+1
RETURN
605:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingRect[2]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[2]
f=f+1
RETURN
610:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingRect[3]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[3]
f=f+1
RETURN
615:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingRect[4]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[4]
f=f+1
RETURN
620:
STYLE "Links"  : TEXT2 0,f*s,"AC_DrawingRect[5]: "
STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[5]
f=f+1
RETURN
!+++ end of parameters
100:
ende = 620
RETURN
2D script is its right place. I try to figure it out, too.
TomWaltz
My first thought was that the DrawingRect was the size of the rectangle, but it seems to be a distance from the origin of the marker to the extremes of the drawing size, so that [1] and [3] add up to the total X dimension and [2] and [4] add up to the total Y dimension.
[5] does not seem to do anything.
Is that what you have found as well?
Tom Waltz
Frank Beister
[5] is the drawing angle. But I do not find the relation to the origin. As strange as the label positioning.
TomWaltz
Not surprisingly, it's in the same goofy logic as the labels, though.\
Maybe GS would be kind enough to clue us in some day?
Tom Waltz
LiHigh
I wish GS is doing these instead of me!
Origin = bottom left corner of the Drawing.
Drawing Width = AC_DrawingRect[3]
Drawing Height = AC_DrawingRect[4]
Layout Width = AC_LayoutRect[3]-AC_LayoutRect[1]
Layout Height = AC_LayoutRect[4]-AC_LayoutRect[2]
Cell Width = AC_GridRect[3]-AC_GridRect[1]
Cell Height = AC_GridRect[4]-AC_GridRect[2]
Howard Phua
Win 10, Archicad 19 INT
Frank Beister
The reference for the three rect parameters is zero-point of the object. Anywhere, where you position it on the layout screen. The orientation of the title block give also the rotation of the coordinate system for the three parameter arrays.
Because it is as the label coordinates, it is nothing new. 😉
The fifth parameter is, because there is no way to rotate the layout or the grid, every time a zero (angle).
To get the right positioning "in space" the parameters SYMB_POS_X and SYMB_POS_Y work too.
But some other of these optional parameters seem not to work:
AC_ConvertedTitle
AC_PreviewType
AC_TitleFitMode
