Title size Parameters?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-08-02 03:16 PM
‎2006-08-02
03:16 PM
How about any "request" information or built-in parameters? There does not seem to be anything in the GDL Dev Kit or the Reference Manual about it.
Tom Waltz
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 03:51 PM
‎2006-08-02
03:51 PM
Create a new object and change to subtype "title block"/"drawing title" (? "Zeichnungstitel" in GER). You will see some optinal parameters (blue) wich will contain the informations you are looking for. (I guess 😉 )
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 05:10 PM
‎2006-08-02
05:10 PM
I was hoping to find a little more information the the rectangle arrays. I'll have to spend some quality time with them later this week when I have a few less fires burning.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 05:18 PM
‎2006-08-02
05:18 PM
Maybe this will help you:
IF not(AC_TextFont="") THEN Zeichensatz = AC_TextFont sh = AC_TextSize ! HIDEPARAMETER "Zeichensatz","sh" ENDIF !+++ DEFINITIONS start = 500 GOSUB 100 !=ende DEFINE STYLE "Links" zeichensatz, sh,3,1 DEFINE STYLE "Rechts" zeichensatz, sh,1,0 s=-sh/1000*GLOB_SCALE*1.5 t=-s/2 !+++ PRINT FOR unterprogramm=start TO ende STEP 5 GOSUB unterprogramm NEXT unterprogramm END !+++ SUBROUTINES 500: STYLE "Links" : TEXT2 0,f*s,"AC_ManualPosition: " STYLE "Rechts" : TEXT2 0,f*s,AC_ManualPosition f=f+1 RETURN 505: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingGUID: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingGUID f=f+1 RETURN 510: STYLE "Links" : TEXT2 0,f*s,"AC_TitleFitMode: " STYLE "Rechts" : TEXT2 0,f*s,AC_TitleFitMode f=f+1 RETURN 515: STYLE "Links" : TEXT2 0,f*s,"AC_TextFont: " STYLE "Rechts" : TEXT2 0,f*s,AC_TextFont f=f+1 RETURN 520: STYLE "Links" : TEXT2 0,f*s,"AC_TextSize: " STYLE "Rechts" : TEXT2 0,f*s,AC_TextSize f=f+1 RETURN 525: STYLE "Links" : TEXT2 0,f*s,"AC_TextPen: " STYLE "Rechts" : TEXT2 0,f*s,AC_TextPen f=f+1 RETURN 530: STYLE "Links" : TEXT2 0,f*s,"AC_TextStyle: " STYLE "Rechts" : TEXT2 0,f*s,AC_TextStyle f=f+1 RETURN 535: STYLE "Links" : TEXT2 0,f*s,"AC_UseUniformTextFormat: " STYLE "Rechts" : TEXT2 0,f*s,AC_UseUniformTextFormat f=f+1 RETURN 540: STYLE "Links" : TEXT2 0,f*s,"AC_PreviewType: " STYLE "Rechts" : TEXT2 0,f*s,AC_PreviewType f=f+1 RETURN 545: STYLE "Links" : TEXT2 0,f*s,"AC_ConvertedTitle: " STYLE "Rechts" : TEXT2 0,f*s,AC_ConvertedTitle f=f+1 RETURN 550: STYLE "Links" : TEXT2 0,f*s,"AC_LayoutRect[1]: " STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[1] f=f+1 RETURN 555: STYLE "Links" : TEXT2 0,f*s,"AC_LayoutRect[2]: " STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[2] f=f+1 RETURN 560: STYLE "Links" : TEXT2 0,f*s,"AC_LayoutRect[3]: " STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[3] f=f+1 RETURN 565: STYLE "Links" : TEXT2 0,f*s,"AC_LayoutRect[4]: " STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[4] f=f+1 RETURN 570: STYLE "Links" : TEXT2 0,f*s,"AC_LayoutRect[5]: " STYLE "Rechts" : TEXT2 0,f*s,AC_LayoutRect[5] f=f+1 RETURN 575: STYLE "Links" : TEXT2 0,f*s,"AC_GridRect[1]: " STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[1] f=f+1 RETURN 580: STYLE "Links" : TEXT2 0,f*s,"AC_GridRect[2]: " STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[2] f=f+1 RETURN 585: STYLE "Links" : TEXT2 0,f*s,"AC_GridRect[3]: " STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[3] f=f+1 RETURN 590: STYLE "Links" : TEXT2 0,f*s,"AC_GridRect[4]: " STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[4] f=f+1 RETURN 595: STYLE "Links" : TEXT2 0,f*s,"AC_GridRect[5]: " STYLE "Rechts" : TEXT2 0,f*s,AC_GridRect[5] f=f+1 RETURN 600: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingRect[1]: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[1] f=f+1 RETURN 605: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingRect[2]: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[2] f=f+1 RETURN 610: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingRect[3]: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[3] f=f+1 RETURN 615: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingRect[4]: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[4] f=f+1 RETURN 620: STYLE "Links" : TEXT2 0,f*s,"AC_DrawingRect[5]: " STYLE "Rechts" : TEXT2 0,f*s,AC_DrawingRect[5] f=f+1 RETURN !+++ end of parameters 100: ende = 620 RETURN2D script is its right place. I try to figure it out, too.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 05:41 PM
‎2006-08-02
05:41 PM
My first thought was that the DrawingRect was the size of the rectangle, but it seems to be a distance from the origin of the marker to the extremes of the drawing size, so that [1] and [3] add up to the total X dimension and [2] and [4] add up to the total Y dimension.
[5] does not seem to do anything.
Is that what you have found as well?
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 06:06 PM
‎2006-08-02
06:06 PM
[5] is the drawing angle. But I do not find the relation to the origin. As strange as the label positioning.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-02 06:15 PM
‎2006-08-02
06:15 PM
F. wrote:Not surprisingly, it's in the same goofy logic as the labels, though.\
Maybe GS would be kind enough to clue us in some day?
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-03 03:37 AM
‎2006-08-03
03:37 AM
I wish GS is doing these instead of me!
Origin = bottom left corner of the Drawing.
Drawing Width = AC_DrawingRect[3]
Drawing Height = AC_DrawingRect[4]
Layout Width = AC_LayoutRect[3]-AC_LayoutRect[1]
Layout Height = AC_LayoutRect[4]-AC_LayoutRect[2]
Cell Width = AC_GridRect[3]-AC_GridRect[1]
Cell Height = AC_GridRect[4]-AC_GridRect[2]
Howard Phua
Win 10, Archicad 19 INT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-03 08:42 AM
‎2006-08-03
08:42 AM
The reference for the three rect parameters is zero-point of the object. Anywhere, where you position it on the layout screen. The orientation of the title block give also the rotation of the coordinate system for the three parameter arrays.
Because it is as the label coordinates, it is nothing new.😉
The fifth parameter is, because there is no way to rotate the layout or the grid, every time a zero (angle).
To get the right positioning "in space" the parameters SYMB_POS_X and SYMB_POS_Y work too.
But some other of these optional parameters seem not to work:
AC_ConvertedTitle
AC_PreviewType
AC_TitleFitMode
AC_ConvertedTitle
AC_PreviewType
AC_TitleFitMode
