Scripting problem w/ Skylight
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-01-08 05:18 PM
2007-01-08
05:18 PM
when I turn "Display text" on, the 2D symbol doesn't appear. The 2D full view looks good and I have the 2 text positions in the "Parameters script"
yet it doesn't display in the Object settings.
I'm at a loss as to what to do, can anyone lend some instruction.
XP AC1010
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-09 04:50 PM
2007-01-09
04:50 PM
Chris:
Based on your description, I am not positive of the result you trying to achieve. The text scripted (added?) at the bottom of the 2D Script window will appear only when the Floor Plan Display parameter is set to Symbolic View, as at the top of the script there is the statement: if AC_symb_display_option = 3 then goto 100: ! Symbolic 2D (see the Master Script for how this is set). If you want this text to appear with other Floor Plan Display parameter options, then you will need to call it from the other parts of the 2D Script where these options are scripted.
If this is not the issue, then you will need to post more information.
HTH
David
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-10 09:16 PM
2007-01-10
09:16 PM
David,
Thanks, I was unable to get time on this yesterday but it seems I had it correct. When I opened today it appeared fine. I'm not sure why the part did not refresh when saved, maybe the library needs to reload after editing?
I had it set to "symbolic" already as I'm after a very basic outline to show on the floor plan below. Works great.
Thanks for your reply. Chris
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 03:54 PM
2007-01-11
03:54 PM
Chris:
Reloading should not be necessary in this case, I did not need to do it when modifying your part to see the changes. But, who knows?, as long as it works.
David
David
