Mats_Knutsson
Mentor
Scripting question > bgcolor from parameter value
Anyone clever knows how to color the label bg color depending on a value from an IFC-property I have a ton of cool uses for this but I don't have a ton of gdl-skills.
AC 25 SWE Full
5 Replies 5
As far as I know GDL has no way of reading IFC values.
Mats_Knutsson
Mentor
ouch
AC 25 SWE Full
alemanda
Are you sure Barry?
How does the category label read IFC values and report them?
Is it hard coded label object?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Apparently, this is possible in GDL:
http://gdl.graphisoft.com/gdl-docs/gdl-guide/chapter-12-miscellaneous/application-query-options/#idm...
If you look into the Tags and Categories Label's script, these GDL commands are used in one of its macros to get those parameters and their values.
alemanda wrote:
Are you sure Barry?
My bad sorry.
Looks like you can read the values as Laszlo suggested (can't say I have tried).
I hope it is not like the Project Info where you can read and display the value but you can't actually use it because it is only an autotext value.
