Selecting doors on multiple storys
I would like to change some Door IDs with ID Manager on entire project. How can I select the desired doors on all storys at once? Is that possible?
4 REPLIES 4
Ben Odonnell
3D window, Edit menu, Find and Select.
That should do the job for you.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Hi Gregor,
You can also use the Interactive Schedule to select desired doors and then change your ID's
Thank you both, but it doesn't do the job for me. I can use 3D window, but then option ID manager is greyed and can't be selected. If I try to change the ID on a big building with many of doors, it is easy to do with ID manager, but with IS would take too long.
I just found usefulness of ID manager to quickly renumerate the doors and windows on my project and I thougth, that I could make a selection of type X door, renumerate them, select type Y,...
Using the ID manager you should be able to change the ID's by criteria or by order of selection and chose the beginning number. Might not be so bad even on a large building.
In the 3D window you can select the types or widths of doors using Find and Select and then just enter the desired ID number in the Info Box and the ID of all the selected doors will change.
Depends on what you are trying to do.
Woody
