SemiArch/EllipseArch GDL Settings
I've copied the W Ellipse Arch Opening and made it into a door (named D Ellipse Arch Opening) so we can have elliptical doors that work with our automatic schedules. We also use D Semi Arch Opening for our arched openings. The semiarch parameter for arch height is header to shoulder and the ellipsearch parameter is sill to shoulder. I'd like to change the semiarch setting to match, so they are the same on the schedules. Does anyone know how I can do this easily in GDL? Any input would be greatly appreciated.
3 Replies 3
David Maudlin
Dean:
1. Create a new parameter for this part, give it the variable "bha" (so it matches the D Ellipse Arch Opening parameter, which may help for scheduling and parameter transfer) and the name "Bottom Height of Arch".
2. At the beginning of the Master Script, add the line:
gs_arc_h=B-bha
This will calculate the gs_arc_h variable (named Arc Height) as the difference between the height of the door and the Bottom Height of Arch.
3. After the !!CURVED TOP CALCULATION!! line in the Master Script are some formulas for correcting the arch height based on the width and height of the door so it does not exceed these variables and create an impossible situation. You can work through these if you are concerned about the users entering a wrong Bottom Height of Arch parameter.
4. Since this work is done in the Master Script, the correct values are passed on to the 2D and 3D Scripts, so you should not need to fool with these scripts.
5. Click on the "X" next to the "Arc Height" parameter to hide it in the part's dialog box.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you!!! That works perfectly!
David Maudlin
Dean:
Glad that worked, thanks for letting me know.
