Set Layer Within Object?
Is it possible to have an object check which layer it is on and reset it if necessary?
3 Replies 3
Frank Beister
The global GLOB_LAYER should help you. (GDL Reference Guide 9.0 p.217)
What do you mean with "reset it"? You can't change the layer the object is on within the script.
That's what I was looking for. Being able to script an object to be on the correct layer would sure help with those users who don't pay proper attention to layering. Oh well.
TomWaltz
You could probably do something like:
IF glob_layer <> "Right Layer" THEN
TEXT2 0,0, "PAY ATTENTION!"
END
ENDIF
at the beginning of the 2D script.
Tom Waltz
