‎2011-02-11 08:25 AM
‎2011-02-11 02:34 PM
‎2011-02-12 03:37 AM
David wrote:I'm not sure if I understand whether this issue is about placing objects or creating objects with a specific default layer coded in.
Anne:
No. Objects are placed on the default layer of the Object Tool.
David
‎2011-02-12 03:53 AM
Paul wrote:The default layers are limited to the tools available in the tool palette. Thus lights, stairs and chairs can each have their own distinct default layers, but chairs and tables and sinks and toilets cannot since they all use the same tool. This is one of the things that favorites are good for.David wrote:I'm not sure if I understand whether this issue is about placing objects or creating objects with a specific default layer coded in.
Anne:
David
David - do you mean that objects are assigned a default layer according to Model Element Subtype?
Anne - I, too, would like to be able to assign a default layer to objects we create, but if the question is about placing objects, my experience is a bit different than what both you and David report. In my AC, the default layer is the last layer I placed an object on, not the Archicad layer. For example, I created an object and placed it on the A-CLNG layer, the next time I tried to place an object we had created previously, the default layer was A-CLNG.
I don't understand how this is meant to work.
‎2011-02-12 04:56 AM
Matthew wrote:Thank youPaul wrote:The default layers are limited to the tools available in the tool palette. Thus lights, stairs and chairs can each have their own distinct default layers, but chairs and tables and sinks and toilets cannot since they all use the same tool. This is one of the things that favorites are good for.David wrote:I'm not sure if I understand whether this issue is about placing objects or creating objects with a specific default layer coded in.
Anne:
David
‎2011-02-12 01:31 PM
Paul wrote:To be clear, there is no way via GDL to assign a layer to an object.
‎2011-02-13 02:02 PM
‎2011-02-13 02:15 PM
Anne wrote:Correct, there is no way to do this via GDL.
I hoped the layer could be an attribute in the Model Element or one of its subtypes. But it is not so ?
‎2011-02-14 06:18 AM
‎2011-02-14 09:48 AM
