Setting window transperancy in 2d plans
olga_kots
Is there a way to set the transperancy of the windows in 2d plans?
I'm planing to export pdf drawing to Indesign and place them on colored background.
The plans itself are transparent exept the windows - they come with white fill.
I've set all I could find in the windows setting to transparant, but still they stay white.
Thanx in advance.
undefined
OLGA_KOTLYAROVA
Andris_Sh
Hi, here is the screenshot with different transparency options. May be you have some kind of graphic override if this does not work for you?
undefined
olga_kots
@Andris_Sh Thank you, yes, it solved case.
But there is one window that still stays filled with white even with same settings.
But that's not crutial.
Thank you for your help.
OLGA_KOTLYAROVA
