Shape of Section Marker
Hi! There is a way how you can change the shape of a Section Marker,
like I show in the jpg?
Thanks.
3 Replies 3
David Maudlin
Giuseppe:
You can change the appearance with GDL. The part you show is Section Part Marker_NCS 11. If you open this part, you will see in the Master Script that it is calling a macro Sect-Elev Marker Macro USA that contains the code for this part. You will need to do some editing in the 2D Script (make a copy of the macro first and give it a unique name, and change the Call in the Master Script) to alter the graphic parts of the object. This is easier than starting from scratch, as the original macro already has the drawing referencing and rotation/mirror issues resolved.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, David I'll we try to night and I hope don't make a mess I will try to follow your advice.
Thank you, I let you know if I succeeded or not.
Hi! David, I tried very Hard but I dont' arrived at any conclusion, I realy don,t know how do it.
