dfks
Side of doors in walls not shown with proper thickness
hi all,
as shown in the image, the sides of the door should be with the same thick pen of the sides of the walls (it should eventually turn around). I'm not using a composite wall because it is not a straight one.
All the pens of the door do not suit the necessary solution.
Would you please let me know where I'm wrong?
Thank you!
1 Solution
Just a guess: Is Ganging turned on for that side of the Door?
Go to post
2 Replies 2
dfks
Hi Laszlo, thank you for your answer. It was indeed that almost hidden setting!
