Sill and board 2d display
Hello
Does anyone know how to make window sill and board visible in floor plans?
Thank you in advance.
9 Replies 9
They must be set ON:
Hello
I have them on. However I'm using symbolic floor plan display for windows and projected for walls due to different height of windows.
If I swap floor plan to projected i see sill and board in 2d but then higher positioned windows disappear.
Does symbollic floor plan allow display of sill/board?
According to this chart:
http://archicad-talk.graphisoft.com//files/wall-window-marker-floorplandisplay-visibilitygrid_479.pn...
I can use only symbolic floor plan for windows and projected for walls, since I'm using complex walls.
My settings: Walls.....Projected; Windows......Symbolic
Sill and Board are visible.
Did you set all the dimensions for Sill and Board?
here are my settings for sill:
and here for dimensions
Check the scale of the floor plan. The sill is only displayed below scales of 1:50 if the window has the '2d Detail Level' set to 'Scale Sensitive'. You can change this manually to 1:50 and it will stay at that detail level whatever the floorplan scale is.
Hope that helps.
It works Thank you!
in previous versions of AC (pre AC12 i think), you could display a simplified frame and sash and still see board and sill (see window A vs window B) which is handy for a number of uses. is this no longer possible?
