2017-11-29 01:24 AM - last edited on 2023-05-24 12:28 PM by Rubia Torres
2017-11-29 04:03 PM
2017-11-29 06:39 PM
David wrote:This was it, thanks David! I did not know there was a second way to create a sill!
jameshart:
I think the issue is that you are using the Frame & Sash setting to create the sill, which ArchiCAD considers part of the window. From your screen shot it looks like you want a masonry sill. Try setting the Closure type to Brick Veneer, then using the Brick Sill in the Wall Closure... panel to create your sill. This will place the sill outside the window dimension.
