Skate parks
I am looking for any skate park GDL's that any body has made. I teach Architecture to my high school class and the boys are designing a park for a new estate and would like the park to include a skate park or half pipe or bowl. I have tried making my own and the closest I can get is using the mesh tool and changing the heights at various locations. Can any one help?
8 REPLIES 8
I have found "half pipe skate piste" object:
And the object :
Thanks. Thats a great start. Would still love to get more.
Mats_Knutsson
Mentor
The mesh tool would work nicely don't you think?
AC 25 SWE Full
Use SLAB for the base plate, then use basic shapes (sphere, cone, cylinder...) with SEO to form curves...
And don“t forget the new SHELL tool in AC15!
Thanks for this tip but what is SEO. We are also only using ArchiCad 14 at present.
Complex profiles should be able to do a lot of what you need as well. And don't forget pool objects!
Jared Banks, AIA
Shoegnome Architects
Rod Jurich
Scotch wrote:
/....... but what is SEO. /......
Solid Element Operation see attached pic.........
PM ....... and I'd be pleased to assist in person.
Rod Jurich
