2004-03-09 07:36 PM - last edited on 2023-05-24 11:06 AM by Rubia Torres
2004-03-09 08:22 PM
Jacek wrote:What you describe is very easy to build as a custom door ... which will indeed show up in the I.S. ... and further will cut its own hole in the wall. Take a look at Rex Max's ArchiTip from March 2003 called GDL 101 (somewhat large PDF file linked here):
I know that I could make them out of wall material etc., but then they will not show win the interactive (?) schedule.
2004-03-09 08:31 PM
It may look a little intimidating, but is quite easy. Just build your door ... and your track .. with slabs, flat on the ground at the origin and project zero as if you are looking at it in elevation. Since the door needs to be outside of your wall, build your door slab as far below project zero as you want it offset from the outside of the wall.Karl,
2018-09-16 12:59 PM
2018-09-17 03:23 AM
