Sliding Door question.
I'm using an interior sliding door for a bathroom entry. Is there a way that I can show it without being attached to either the left or right side just in the middle?
5 REPLIES 5
Not sure what version of AC you are using
But if you'r using AC 12, you can try Curtain Wall to create a sliding door like you said. It's free standing (does not need any wall)
I'm using ac11. Does that feature exist in 11?
Curtain wall was introduced in 12.
How about just modeling the door slab from a wall and
put it in a "door" which has empty opening.
Then you could place it anywhere you want.
lec
Erika Epstein
If you set the contruction method type from EDGE to SILL then you can set the set back dimension so the door sits in the middle of the wall.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Be aware of this problem which also occurs in AC11 when transferring parameters to sliding doors (i.e. don't!) -
http://archicad-talk.graphisoft.com/viewtopic.php?p=148078
