3 weeks ago
- last edited
3 weeks ago
Hi there,
I would like to add a vertical mullion that splits the glazing above the sliding door. How would I do this? The name of the door I am using is "sliding door with Transom".
Solved! Go to Solution.
3 weeks ago
- last edited
3 weeks ago
You should probably have a quick flick through the settings of the objects in question before posting here. You would probably save yourself some time.
3 weeks ago
- last edited
3 weeks ago
3 weeks ago
Thankyou. I tried the H-V Grid and that didn't work but then tried Divided Frame and that worked perfectly.
Best,
Clauds
