Find the perfect object, manage libraries, create custom objects
SOLVED!
Sliding door with 2 slidelights tool
Chris Pooley
I am wondering how to set the fixed glass sidelight panels to central in the frame, so it is like the actual sidelight.
Does anyone know? I have been through the selection settings a few times, I cant work it out.
Thank you,
ArchiCAD 19 to 27
Windows 11
1 ACCEPTED SOLUTION
Solution
Chris Pooley
Hi Again, Never mind, I worked it out.  = Sidelight Rebate Depth on the Frame Style and Dimension heading:-
Sorry for the inconvenience.
ArchiCAD 19 to 27
Windows 11
1 REPLY 1
Solution
Chris Pooley
ArchiCAD 19 to 27
Windows 11
Setup info provided by author
