Sliding door with 5+ sliders
Ive always had this issue of wanting to use a sliding door with more leaves.
In the past ive always just had to use Multi-sash windows and use linework for other parts.
Is there really no way to have a sliding door with more sliders, the options for a sliding door seem so restricted/limited.
If theres any suggestions for doing more custom sliding doors, any help would be appreciated.
Thanks
3 Replies 3
Lingwisyer
Guru
There was a Marvin one available free somewhere that can do this. The one I found a while back was called "Marvin Door Modern - Multislide" and it could do upto 6L6R stacked or pocket. I have yet to use it though. I think they also have one that can do 10, but these are made to the brand. I believe the CADImage doors can also do this as well, along with a whole a lot more, but that is a paid addon...
Ling.
Eli Chiasson
Is is a sliding-folding door you're looking for? The D1 Sliding Folding Door from the AC21 INT Library supports up to 14 leaves.
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
AC19-23 USA+MEP • i7-7700 3.6GHz | 32GB RAM • Windows 10 Professional
Erwin Edel
For 3d representation I've combined two sliding doors to get 6 (3 to one side). Set the one of the side frames to combine and set the width of that frame to 0. Doesn't help your schedule, of course.
I don't understand why we can 3 doors to one side and not 6 to either, but it is what it is.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
