Small error message - what does this mean?
rob2218
I'm getting this very small error message soon as I open a PLN each time.
I'm sure it's an object that has some messed up coding on some line or missing some other object it's trying to find but how can I find what this object is so I can remove it?
thanks,
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
The image "cadi_InteriorTrimFilters" is missing when called by the library part Master_GDL_pro11.gdl (I think it comes from version 11).
You have to load the full library (folder or .lcf)!
rob2218
OK...so....say I don't want to load the full AC11 library...how can I remove "whatever" the object is that is searching for out of this project so I don't get this error message anymore?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Find "Master_GDL_pro11.gdl" with Library Manager and DELETE it.
