Some help with trigo
I would apreciate some help for this trigonometrical problem.
I am searching for H or ang, function of X and ray. I don't find a solution.
Thanks to anyone for the highligth.
16 Replies 16
Law of Sines. I think. Not that bad if I'm right.
a/SIN(A)=b/SIN(B)=c/SIN(C)
The angle we know, A=135. Opposite is the side we know, a=R.
The other side we know, c=ray.
You're looking for B.
R/SIN(135)=ray/SIN(C)
SIN(C)*R=ray*SIN(135)
SIN(C)=(ray*SIN(135))/R
C=ASN((ray*SIN(135))/R)
B=180-A-C.
Something like that.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
David Collins
Unsolvable, I think.
X minus the endbit (and therefore H) could be be anything, depending on the value of ang.
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
Frank Beister
I think it's solveable, because the triangle over 'X' makes the figure stable.
SIN(ang)=H/R
SIN(ang/2)=s/R
X=d1+d2
d2=H*TAN(45)=H
TAN(ang/2)=d1/H or SIN(ang/2)=d1/(2*s) or COS(ang/2)=H/(2*s)
I have not the time to solve it, maybe later or someone else wants...
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
Frank Beister
Sorry, I haven't seen that James has the solution yet:
ang = 180 - 135 - ASN( ray*SIN(135) /R)
B=180-A-C.
Thank you so much, James, you save me. It works perfectly.
The link posted by Bill is helpful, too. Thanks to all for your help.
Vitruvius
I think the formulae are:
H = X*SIN(45) --- X being the hypoteneuse of small triangle
Ang = ASN(H/R) --- and then plugged into the large triangle formula
Assuming from your diagram that X, RAY, and 45d are known values.
Cheers
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Cheers
Not exact, H = R*sin(ang)
For the rest, X, ray and 45 are known.
I did i first try with the sum of angles into a triangle, another one with pythagoras (Frank's example), without success.
I can assure you that James's solution works perfectly. The occasion for me to rediscover this "sine rule" (Bill's link).
Thanks anyway.
