Stress Co_
Special Edition Library-Copy Door parameters to a diff. door
Prior to using the SE Library....
I was able to set all my parameters for a door (say D1): line types, offsets, trim, frame thickness, etc. "eyedropper" the door in plan to copy the attributes...... then open a new door "settings window", ... and "inject" the parameters into a different style door (say D2). Worked great.
But It doesn't work with the SE library. Any work arounds or am I doing something wrong?
Marc Corney, Architect
Red Canoe Architecture, P. A.
5 Replies 5
TomWaltz
Are you using both the regular and SE libraries? Or just the SE?
Tom Waltz
Stress Co_
Just the SE. It's the Parameter Transfer within the SE library thats not working.
I just found this:
http://www.graphisoft.com/support/archicad/downloads/library_updates/usa.html
and I'll see if it solves the problem. I'm using the 1st version of SE lib.
Thanks
Marc
Seiss Wagner
Actually, parameter transfers using the eyedropper work great in the SE 9 library, it was one of the few things I really liked about the new library. However, I was working with the latest version and the older version may not functioned properly. Download the most current version and try again, I think you will find it works fine.
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
Kind of a New question, but what is the latest SE Library? With PC, I have selected the Properties of the SE PLA file (See Attached). This PLA extracted from a download of "AC9 Library Special Edition.zip" that I downloaded on Nov. 4, 2005. The Extracted files seem to have been created on Oct. 3, 2005 and the PLA has a Written By: AC 9.0(1812).
Is this the Latest US AC SE 9 Library?
Stress Co_
No worries now. The update solved the issue (but I had a bit of hassle to find some missing objects in my master template).
Jay... did you check the dates here?:
http://www.graphisoft.com/support/archicad/downloads/library_updates/usaSEdownload.html
