Splay Bay AC12
I've just noticed that when you apply a HV grid to the "W Splay Bay 12" in Archicad 12 it leaves gaps on the frames whilst in 3D view.
I've played around with most of the settings but the gap will not disappear, is there anyway to get the frames to join up? or is this a bug.
Hello Marcus,
Have you tried updating your library?
Adrian Tudoreanu
Just checked if my Archicad 12 and Archicad Library is up to date and there both up to date.
Build number: 2782
David Maudlin
Marcus:
I don't know the cause, but it looks like the lower windows (and upper side windows) are missing the sash frame which is shown in the upper central (transom) windows, which causes the gap. I do not get this problem (and could not find a setting that would cause it) so you might see if you can download again and reload the library. The library version is LIB12-USA-2528-Mac.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
