ā2015-07-11 06:18 AM
ā2015-07-12 11:34 PM
ā2015-07-13 12:02 AM
ā2015-07-13 01:10 AM
arqrivas wrote:It would be pretty easy to do either way
Thanks, Seneca
that's a solution a least for the 3d view but I need a full solution.
Thanks anyway, I'll keep on looking. Maybe I will need to make it myself.
ā2019-01-08 03:54 PM
SenecaDesignLLC wrote:Hi, Seneca
if you set the resolution to 4 then the circle becomes a sqaure, but you will have to make a copy of the object so you can have the 2d be a square as well.
