Square recessed Spot Light
Hello everyone, I've been looking for a square recessed spot light, but I can't find it and archicad has only a round one. Do you Know where to find one? or at least how to do one that can be scheduled as a light? Thanks
4 Replies 4
if you set the resolution to 4 then the circle becomes a sqaure, but you will have to make a copy of the object so you can have the 2d be a square as well.
Thanks, Seneca
that's a solution a least for the 3d view but I need a full solution.
Thanks anyway, I'll keep on looking. Maybe I will need to make it myself.
arqrivas wrote:
Thanks, Seneca
It would be pretty easy to do either way
Hi, Seneca
I'm having the same issue. How can I change the resolution? Is it in 2d and 3d scripts?
Thanks!
