Stair library not available for wood stairs
theonlydesignguy
I cannot seem to access wood stair options.  I have checked the library and it seems to be there. I have reloaded it and restarted.  I am at a loss.
Operating system used: Windows 5003
Open your favourites and see what options you have there.
If you have no favourites, then import them from the default template - that will give you a start.
Otherwise you have to set them up, by turning the 'structure' = off and maybe 'stringers' = on, 'treads and risers' = on.
theonlydesignguy
Screenshot 2024-05-02 223257.pngI can't click on any of the flight structure or landing structure images after I uncheck "structure"
Sorry, leave structure on but change to stringer or beam or cantilevered.
In 'Finish' turn 'finish' on and choose from tread or risers or both.
Setup info provided by author
