theonlydesignguy
Stair library not available for wood stairs
I cannot seem to access wood stair options.  I have checked the library and it seems to be there. I have reloaded it and restarted.  I am at a loss.
Operating system used: Windows 5003
3 Replies 3
Open your favourites and see what options you have there.
If you have no favourites, then import them from the default template - that will give you a start.
Otherwise you have to set them up, by turning the 'structure' = off and maybe 'stringers' = on, 'treads and risers' = on.
theonlydesignguy
Screenshot 2024-05-02 223257.pngI can't click on any of the flight structure or landing structure images after I uncheck "structure"
Sorry, leave structure on but change to stringer or beam or cantilevered.
In 'Finish' turn 'finish' on and choose from tread or risers or both.
