‎2007-08-23 11:12 PM
‎2007-08-24 01:58 AM
‎2007-08-24 03:32 AM
‎2007-08-24 10:51 PM
Peter wrote:Yes, it's something you have to want.
Hello James,
Thanks for posting back.
I guess the reason I never could see the difference between 1 and 2 when
using CUTPOLYA is that I always set the material and pen for the
CUTPOLYA the same as the pen and material of the element being cut.
The first time I used CUTFORM I set j1 to 1 and j2 to 0I'm not observing that, but I'm not trying anything fancy, just CUTFORM on PRISM_. Sounds buggy. I get the proper result from status=1 and status=2. It will take status=3 (1+2; j1 & j2 both on), but it treats it as status=1. So if that clears up the section, do it.
thinking that the two were mutually exclusive as in CUTPOLYA and
when I viewed my object in section the object appeared
hollow and some of it's surfaces were transparent or disappeared.
Setting j2 to 2 fixed things.
‎2007-08-24 11:29 PM
‎2007-08-24 11:44 PM
Peter wrote:Hm, I have them under CUTFORM -> status as far back as 9.
You refer to "The j7 and j8 status switches".
In my GDL manual the status numbers only go from j1 up to j6.
‎2007-08-24 11:57 PM
‎2007-08-25 11:35 AM
‎2007-08-25 12:21 PM
Juha wrote:Unfortunately these mask values never worked. Contour lines are always visible, when j7 (64) = 0.
Has anyone ever seen a COONS with working edge line status?
‎2007-08-26 10:36 PM
